Old 03-29-2018, 11:44 PM   #7 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Wow! Hiking 3/8 mile to reach your house. What a different world than my coastal Southern Cali home. I searched the 1992-1995 Civic FSM, which includes your engine. Your compression ratio was slightly higher than other Civics of that generation at 9.3 (instead of 9.2 or 9.1 for other trims). But a document search turned up no results for compression test. I might search again. But I think 184 is the more precise number and you are more than 10% over that. High compression can be associated with pre ignition.
EDIT: I found a compression reference in the service limits section. 184 +/- 28 is considered within limits. See attached screen shot.
Name:	2018-03-29 21.00.58.jpg
MetroMPG (03-30-2018)
