This may be a "Road Spray" prevention device. Was the RV'er pulling a vehicle?
I believe UPS was one of the first to implement these on their semi trailers in the late 80's / early 90's (these were mounted above the wheel and hung maybe a quarter of the way into the wheel's diameter).
I asked a driver at the time what they were. It prevents rain or snow spray from interfering with passing or following vehicles -- in an attempt to prevent limited visibility. Nice courtesy -- most likely it's so they wouldn't get rear-ended or side-swiped. I'm not sure if they're using them anymore, but you can see some worn ones on the older trailers.
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
 _
 _
