Old 04-02-2018, 10:01 AM   #21 (permalink)
MetroMPG
90 day: 55.97 mpg (US)
90 day: 70.75 mpg (US)
90 day: 61.17 mpg (US)
woo hoo!
Looks super familiar!
One of my shortest-duration ownership experiences: http://ecomodder.com/forum/showthrea...-vs-33736.html
And not because it wasn't a good car. Probably the best screwed together subcompact I've owned.
Hopefully you don't have the fatal flaw/Achilles Heel rust at the rear of the rocker panel/axle mount like mine did. (I suspect not, given your enviable locale/climate.)
Originally Posted by Stubby79 View Post
So what's left, in an automatic and gets 30+mpg? Couldn't find a Prius cheap enough.
I really liked the Echo, but I LOVED the Prius. Have you driven one? Ideally suited for the commute you described.
I would suggest you keep looking for one and pounce when the right (ie. cheap enough) one comes up. Then sell the Echo -- on which you will probably be able to make a wee profit, given the tidy-up and maintenance you've done.
