Old 04-03-2018, 11:20 AM   #11 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Thanks for this. Good news.
I did the calcs for this for my car, and I like the results.
I get an angle of 3.69º for the diffuser's upward slope, using existing available attachment surfaces. That's assuming the panel prior to the diffuser is horizontal, which I believe it is. Pretty close, anyway. The rear bumper lip is 2" higher than the existing support I'll use to support the diffuser's leading edge (which will also support the prior panel's trailing edge). The diffuser is 31" long at the center, so that's an angle of 3.69º per a handy calculater on the web. Allowing for the bumper's curve, if the diffuser length is only 25" at the sides, the angle is still 4.57º. According to the chart you posted, either case gives a reduction in Cd. Thanks!
The calculator I used
Coast long and prosper.
