Originally Posted by LibertyMKiii
Just curious, why do you say with KPro V4 your car is not street legal?
-Liberty
Technically Any change to the emissions system is illegal. even most cold air intakes. That is not to say most officers will ever give a $#!t. but technically....
Emissions legalities have never stopped a hottroder/ecomodder before!
Originally Posted by Ecky
What'd you end up doing with fuel pump and lines? Is the Insight's stock fuel pump adequate for 3-4x the peak flow?
For a stock accord engine application, it shouldn't be a problem. I just used a cheap knockoff aeromotive fuel pressure regulator. the stock pump is rated between 49.5 G/hr and 58.8G/Hr.
I may have to change to a larger fuel line with the TSX motor.
