Originally Posted by Ecky
The headlights need a polish and I'll probably want to replace a lot of bulbs with LEDs.
While you're swapping out the bulbs... you can also swap out the cargo / trunk light with a drop-in replacement that has a built-in switch so you can turn it off and keep the hatch open when needed.
More info here:
https://www.fitfreak.net/forums/fit-...ll-w-pics.html
Unfortunately the pics are gone from that thread, but they have the part numbers for the replacements.
Another thing you can look at is swapping out the battery for a bigger one. Yep, it will add a little weight but I've found it to be effective. (I have the GE not the GD model.) I've run down the standard battery several times in the past. I upgraded to a better battery and have never had that problem again.
