Old 08-28-2008, 09:01 AM   #17 (permalink)
thebrad
I REFUSE!
thebrad's Avatar
VTEC Express - '96 Honda Civic CX
90 day: 57.72 mpg (US)
Send a message via AIM to thebrad
If your car is automatic you will have to stick with the HX's CVT, if you're manual your transmission should bolt up but the gearing won't be ideal. The CX and HX manual transmissions shared the same gearing, I don't think that was the case for the DX and higher trims.
Also, I think you would have to get another ECU if you are swapping into a manual car.
