Originally Posted by IndyIan
I hope you are pulling our legs.... Changing the pressure everyday...
What worked for me is not worrying about my tire pressure anymore. 42 psi "cold" is about as hard as I want for my crappy roads. Some hot days it might go to 45psi! And I get home just like every other day. People should worry more about running their tires at to low a pressure, 15 psi under probably has killed many more people than 15 psi over.
Ian
You are absolutely correct by stating more people killed by TP neglect than over-pressure "blow-outs" ( when was the last time you heard of this?).
"Pulling our legs?" If you want to answer the unusual questions in life...you're gonna have to do unusual things. No, I am not pulling legs, here. I am an engineer...I don't pull legs.
