Old 04-28-2018, 11:38 AM   #15 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.53 mpg (US)
Another thing to consider: while pumping losses do change with the amount of vacuum, probably more important is the ratio of fixed parasitic losses to power output. You're sapping the same amount of power spinning A/C, alternator and water pump at 3000rpm regardless of how much power you're asking of the engine. An engine closer to peak output at a given RPM will have a better ratio of useful work to parasitic losses.
