Old 04-30-2018, 01:09 PM   #358 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Car is off the road again. Been servicing the transmission but most importantly, I have begun the head gasket too. Gotta get 'er done soonish but be patient enough to do the new process correctly. Right now, waiting for penetrant to loosen intake manifold bolts.
Transmission service pro-tip: I have been using a cleaner in the oil. The process has revealed to me that it had too much oil in it and that was largely responsible for my shifting stiffness. I had initially filled the trans the way dudes on honda-tech recommend: get to level ground and fill until it drips out the filler hole. But that is too much, in my case at least. I got foamy tan-colored oil out of the top of the transmission when I opened the filler hole. So, the lesson is that the FSM says it takes 1.9 liters, folks: measure it precisely and benefit immensely.
The Following 3 Users Say Thank You to California98Civic For This Useful Post:
deluxx (05-03-2018), PaleMelanesian (05-01-2018), Xist (04-30-2018)
