Old 05-05-2018, 03:55 PM   #366 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Valve lash adjustment for FE or emissions?
With my head at the machinist through the weekend, I am working on two or three ecomods. Reinstalling a slightly rebuilt set of wheel skirts, removing and modestly redesigning the side skirts, and most importantly trying to learn if there is a way to do a "fuel economy" or low emmisions valve lash adjustment when I put the head back on and must adjust the valves.
I think tighter lash on both the exhaust and intake will produce longer, earlier, and later openings of the valves and increase overlap. What do you think? A reduced gap between the rocker and the valve stem means longer duration of the opening, with earlier opening and later closing, I think. Overlap is good for scavenging.
