Originally Posted by Xist
I don't think so; pretty sure there was more detail in the one I read. For all I know it could've been one of the other forums (the nissan micra or mitsubishi mirage one). It was a while back so I don't exactly remember.
Originally Posted by California98Civic
My wheel well skirts are very similar. But the skirt overlaps the exterior of the body, creating a clamping effect between the clip, skirt, and body exterior. The hold has been durable over maybe 30,000 miles or more.
My skirts are easily removed, completely. When I remove the shirt from the clip, nothing holds the clip on the lip of the wheel well but light mechanical tension. Sometimes the clips fall to the ground on their own after I remove the skirt. I would recommend using some trim tape or black caulk as a cushion between the skirt and the body, because the paint does get scratched, not that I care much because the scratches are under the skirt.
You just got me thinking here. What if I used something like the following with this
metal plumbers tape:
Color coding:
Gray: wheel well lip of the car
Red: metal bracket from bent
plumbers tape
Brown: side skirt material
Blue: screw
Is that similar to what you did?
