Old 05-12-2018, 11:05 AM   #159 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by mpg_numbers_guy View Post
... So something like that could possibly work, but only if I had a belly pan and rear diffuser installed to stop the parachuting?
Toyota seems to think it can work when a diffuser is incorporated into it, and they have some of the best aero engineers in the world, I am sure. But you do not want a race diffuser, designed for reduce lift. That will also induce drag. You want a design angle that is quite a bit gentler. On my Civic coupe that meant 4* rise from behind the rear axle to the rear bumper cover. I cannot prove it works. I just know the science says it probably does, if I executed it well enough.
mpg_numbers_guy (05-12-2018)
