Do people not hear their engines running?
My Volt has keyless start. It'll honk 3 times if you close the door while it's running and the key isn't inside. It'll also turn off after a couple hours in park if there's been no activity (you can get around it by putting a rubber band around the shifter to keep the release pressed down, if you're sleeping in it or using it as a generator).
If Chevy can get it right, how hard can it be?
