For the record, When I check for vacuum leaks, after I spray it down and I don't find anything. I then squeeze all the vacuum hoses one at a time with a pair of smooth pliers (no teeth) to see if it makes a difference. In your case....Squeezing the hoses still may not have made much of a difference to pick it up quick. but if you were looking at a scanner at the MAP and did that you might pick it up... Congradulations
How about a 1 Litre Street rod?
