Old 05-23-2018, 05:30 AM   #10 (permalink)
niky
I read somewhere that concrete roads are more cost effective in the long run than asphalt, but nobody wants to front the initial cost. It also reduces rolling resistance if I remember correctly.
Big difference. There's a reason that NEDC "cheating" test facilities use trick asphalt... you get a mathematical bonus for using asphalt in the tests, because it is higher friction than concrete. Then you slick it down for lower friction and take advantage of the unfair multipliers.
