Old 08-29-2008, 08:13 AM   #34 (permalink)
vtec-e
vtec-e's Avatar
De Yaris - '04 toyota yaris T2
90 day: 69.55 mpg (US)
The airflow in the civic is ok most of the time with the fan off but if its wet out, the car steams up. So i glued a small plastic scoop over the intake for the ventilation and it helped a lot. The airflow was like the fan was on the one or two setting. The scoop was only above the edge of the hood by half an inch and was only about 5 or 6 inches wide. It worked well, until i turned on the wipers! I had misjudged how far the wiper arm moves and it promptly removed my air scoop! But until then, it certainly worked well. I might re-install another one now that winter is approaching and steamy windows beckon.
ollie
