Old 05-31-2018, 12:33 PM   #19 (permalink)
arcosine
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
That's because he couldn't ignite the lean gas mixture unless he squirted some diesel in. This was done on LP powered locomotive diesel engines in the 80s.
Originally Posted by California98Civic View Post
I have not tried it.
But damage is not just possible but almost inevitable, on a time horizon too near and at a price too dear for anyone on a normal budget and in need of their car on a daily basis.
I watched the "Engineering Explained" vid you linked to as well. But I think he implicitly answers the question of whether this is a good mod for a standard road car in his explanation. The engine he describes was was specially designed with dual ports for differently timed injections of the two fuels. It also had a super high 16:1 compression ratio and outlandishly lean AFRs programmed into the ECU, such as 45:1 at times.
So, I would never try it on my car. I would not expect more than a marginal benefit in engine efficiency from just mixing diesel with gasoline in a conventional gasoline engine. I would expect engine damage, the likelihood of which would depend on how radical you are in the mixture.
- Tony
