Old 06-04-2018, 12:45 PM   #11 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Does anyone know if the different trims correct for the different tire sizes, or is it small enough they just don't bother? If I were to correct for different tire sizes, what would need to be done?
I doubt it. The Civics don't. And the Sport and Base manual transmissions have the same gearing, so I bet the VSS, which is embedded in the trans, is also the same.
But if you are staying below 55mph most of the time, get lighter smaller, LRR tire/wheel combos so you can benefit from reduced rotational mass.
Ecky (06-04-2018)
