Old 06-10-2018, 10:14 AM   #7 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by jimhs View Post
Hi all,
A quick update,
I borrowed same tools and did a small service the other day,
old plugs had an excessive gap, so I guess they were the original ones, from the factory..
Old air filter was the worst I have ever seen..
The oil was really black and kinda thick and I am really glad I change it.
This might also will boost my mpg as well.
It's time to shop around for my own tools.
Regards
Nice job, hey. The plugs and filter replace will certainly help engine function immediately. It might help FE too. Might not be perceptible, but you had to do that stuff, of course.
You could just get tools on a need basis... start with a ratchet an a small set of heads covering the common sizes on your Toyota. The most common will be 10mm-17mm, but sometimes an 8mm and a 19mm. Buying piecmeal is not the cheapest in the end, but it makes the smallest dent in a tight monthly budget.
