Old 06-14-2018, 02:53 PM   #82 (permalink)
oil pan 4
I know the leaf brick has varistors, I installed 2 big 130v MOVs on each line to ground when I did the 120v to 240v mod.
My 16 amp 240v after market EVSE probably has a single small 300v+ MOV wired L to L.
I don't see them as being effective strike protection.
If the car is hit with the bolt, that energy will try to ground through the EVSE if plugged in, which will fry it.
If the lines are hit while the car is plugged in but not charging I expect it to maybe damage the EVSE control circuits.
Late at night, most nights my car is still actively charging.
