Old 06-20-2018, 10:06 AM   #8 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
From my car's garage page, all for a Civic or the like...
Possible wheel swaps:
13" CRX HF OEM (higher RPM & just under 13lbs)*
13" Civic VX 8 spoke (higher RPMs but only 9.7 lbs.)
14" Civic HX 8 spoke (approx 11.75 lbs)
14" first generation Honda Insight (11lbs)*
14" Civic Hybrid 2003-2005 (approx 14 lbs)
14" x 4.5", 4x100, 46 Offset, 56.1 center bore (2014 Mitsu Mirage)
15" Mini Cooper R81 Imola 7-hole (12.1 lbs)
15" Mini Cooper R86 star-spoke (15 lbs)
15" Mini Cooper R96 7-spoke (13.8 lbs)
15" Enkei Classic J-speed (14.1 lbs)
15" Enkei RP-F1 (9.5 lb)*
15" Kosei K4R (10.7 lb)*
15" Konig Helium (11.2 lb) 40mm offset, hub bore 73.1mm*
15" Acura Integra GSR (94-95, 16lbs)
mpg_numbers_guy (12-11-2018)
