Try to discover cold fusion then talk about verticql farming.
You will need a lot of energy to grow food using lamps.
Originally Posted by Xist
Didn't we discuss vertical farming a while ago? They promise world peace, new and improved emojos, and hats that truly make you look ironic, all through the magic of solar panels and LEDs!
How efficient are those two technologies? How does that ever make more sense than direct sunlight?
A professor at Arizona State said it was difficult to do an energy audit there because it had been designed with the promise of abundant and cheap nuclear energy. If electricity becomes cheaper than land then maybe vertical farming would make sense. Yes, you can control the environment (like you can in a greenhouse), and you can adjust the bandwidths the plants receive, but how many bandwidths do solar panels receive?
