Old 06-23-2018, 04:13 PM   #3 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Don't throw parts at the problem until you have properly tested and know what the issue is. You could waste money and time and get angrier. Your FE drop could be caused by a few things, including a vacuum leak or a bad MAP sensor. How do you know it is the O2? You have a code? (Btw, you can't use the wide band in a non-leanburn Civic).
EDIT 1: I thought you had an LX, but you have the EX. It might use a wide band. Not sure.
EDIT 2: Also, does a Torque app need calibration? Part of your problem could be the app is not calibrated properly and is misinforming you so that you get quite a surprise when you get to the pump. Calibration might help.
The Following 2 Users Say Thank You to California98Civic For This Useful Post:
mpg_numbers_guy (06-23-2018), Xist (06-23-2018)
