Old 06-24-2018, 11:05 AM   #10 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
You definitely need to test the circuit for that O2. That is a circuit code. It is probably the sensor. It could be an open in the circuit, even an intermittent one. Don't spend your money on an O2 without testing. Testing is easy. Though you may end up in the same place, you will know you are in that place, rather than having guessed. If it is an open in the circuit, the fix could be quite a lot cheaper. To me this is good eco practice too: not trashing and replacing perfectly good parts.
mpg_numbers_guy (06-24-2018)
