Old 06-24-2018, 03:27 PM   #11 (permalink)
mpg_numbers_guy
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 63.99 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
Team Mazda
90 day: 38.2 mpg (US)
Originally Posted by Stubby79 View Post
Has the torque app been this far off before? If not, perhaps there was human error in the fueling process/math.
Torque has never been this far off for me. It's been no more than 5% off before, and it's uncalibrated since I have only the Lite version so far.
I also filled up at the same pump at the same station as I normally do.
Cutting off the old plug and splicing it to a new sensor uses about $1 worth of solderless connectors.
I'll have to see about if I can do that or something similar if/when I replace it. Still ugh though lol.
When I had an 02 error code "Heated" was part of the description. Doesn't the sensor heat itself as needed? I think that heating it is also part of the troubleshooting.
I'm not sure lol. All I know is that my MPG sucks right now and I hate it!
I am sure that there are good brands. I just know that for Hondas with lean burn, everybody who has tried non-standard oxygen sensors has ended up purchasing NGK\NTK, although often from a different source. I only bought Honda parts to replace my timing belt (and the rest of the belts, the hoses and seals, etc.). I think that the original water pump and hoses have 195,000 miles on them.
There are some situations where the manufacturers cannot get their act together, like Subaru and their head gaskets. When I replaced mine I bought Fel-Pro, but if you can get a good price for Honda parts, I cannot imagine using aftermarket ones.
Just asked him for the exact price and he said it would be $215.
This bad sensor is decreasing my FE by about 19%. Replacing it will save me ~$0.01 per mile. I will need to drive 21,500 miles for it to pay off. I don't even drive that much (I've driven not quite 2000 miles in 5 months) so that's over 4 years until it breaks even. And the car still drives with the bad sensor. BUT I HATE GETTING THESE BAD MPGs so if I need to replace it I will...I guess..
Originally Posted by California98Civic View Post
You definitely need to test the circuit for that O2. That is a circuit code. It is probably the sensor. It could be an open in the circuit, even an intermittent one. Don't spend your money on an O2 without testing. Testing is easy. Though you may end up in the same place, you will know you are in that place, rather than having guessed. If it is an open in the circuit, the fix could be quite a lot cheaper. To me this is good eco practice too: not trashing and replacing perfectly good parts.
Good point. looks up youtube video That looks complicated but I guess I'll give it a go when I can find the time to take it all apart. I've never worked on an engine before sooo.....
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
