Originally Posted by Xist
Did you reuse the head bolts? How come you replaced everything else?
Yes I reused the head bolts, but if you do that, you must create a numbered template of their positions in the head. Get a piece of cardboard and an indelible ink pen and make holes that represent where the bolts go. As you pull the bolts out put them in the corresponding numbered holes in your template.
I replaced the other gaskets and oil seal to avoid leaks. They are all one-time use kinda things. It prolly matters little with the exhaust mani gasket. But the intake gasket you have to replace. A leak there will cause the engine to run badly.
Also, MAKE SURE a pro machines the head to make sure it is level and that you clean the block's deck really well. It will have caked on gasket material. Look up safe procedures for using a blade or pads to really clean all the remnant gasket material or your new gasket will leak for sure. My one area of worry about my job is the possibility that I maybe did not get the block clean enough. Time will tell.
