Old 06-28-2018, 12:07 PM   #15 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Surprise!
Got a nice surprise.
I don't know if it will last, but suddenly the rich condition was gone on my return freeway run last night.
To recap, I tested and replaced failing ignition wires and spark plugs but the very high STFT readings (as high as -29) continued at idle freeway steady cruise across two drive cycles. I did my freeway cruising using P&G last night (third drive cycle) on the way out to appointment and the LTFT, as expected, improved from -9.4 to -5.4 as I expected. That's normal LTFT behavior for P&G. On the way home I wanted to see the negative fuel trims again and observe, so I steady cruised it, but all STFT readings were normal.
It seems possible that the ECU has "learned" it faces normal conditions now. But I am gonna wait a few more drive cycles and use the sensors for diagnostics. Maybe an intermittent failure has gone away temporarily.
The downstream O2 sensor reading is still fluctuating a lot, though, so I still think I need to clean or replace the CAT.
