Old 06-28-2018, 10:54 PM   #12 (permalink)
redpoint5
90 day: 29.78 mpg (US)
Originally Posted by Raj174 View Post
They are currently set to 36 psi. What pressure do you recommend? Sounds like it might stiffen the ride and wear the tire tread down unevenly.
It will cause a stiffer ride and probably a little more road noise, but it shouldn't affect tire wear. I run somewhere around 43 PSI on my Acura and appreciate what it has done for handling, but dislike the extra noise. Just experiment and see what is a good compromise for you. The higher the pressure, the better the MPG.
Effic1ent1 (06-28-2018)
