Old 07-03-2018, 12:16 PM   #60 (permalink)
freebeard
I posted the picture[s] as an example of a reverse trike that wasn't an Arcimoto FUV. I could have used a Bug-E instead.
That sailplane canopy is laid right over what may be a door cut-line. Not even fastened down.
The front tire section is too big for the weight it carries. The aerodynamics is dirty below the beltline. Ingress/egress.
If you solved all the problems (except the un-panted rear wheel) it would look like one of these:
You can't be wise and in love at the same time. -- Bob Dylan
