Thread: pwm frecuency
Old 07-05-2018, 08:55 PM   #2 (permalink)
Piotrsko
Should generally be about 8khz for most power igbts today at the low end. Newer ones are faster and therefore generate less heat as a rule of thumb.
Comments: sure your measuring method works?
I could see 4 khz because you are using 1/2 the base frequency, And you should have some divisor process in the control chip.
