Old 07-05-2018, 05:14 PM   #1 (permalink)
Ale Madeo
ale0502's Avatar
pwm frecuency
Hi,
I understand that the pwm frecuency must be 10KHz, but on my board I have about 3KHz.
Any idea what´s wrong?
I have an 8MHz crystal.
thanks
Los que dicen que es imposible, no deberían molestar a los que lo están intentando...
Old 07-05-2018, 07:55 PM   #2 (permalink)
Should generally be about 8khz for most power igbts today at the low end. Newer ones are faster and therefore generate less heat as a rule of thumb.
Comments: sure your measuring method works?
I could see 4 khz because you are using 1/2 the base frequency, And you should have some divisor process in the control chip.
