Thread: Solar HHO
Old 07-06-2018, 09:05 AM   #3 (permalink)
ratgreen
You'd be better off using that solar to charge your battery and deleting your alternator.
To make a long and complicated story short, hydrogen can work to speed up combustion which can improve efficiency. But, in order to see any real gain the engine must be tuned to burn lean (which slows down combustion). Unless you are willing to totally reprogram your fuel computer, its not worth it.
This would be going on an old diesel, which wouldn't just add extra fuel to compensate like a modern EFI engine would.
So this would just increase the efficiency of the current amount of fuel as there is no computer, purely mechanical injection pump.
