cwwebster I also found MTT Micro Turbine Technology BV that is building a high speed turbine generator for large home or small business use. It seems that there will be many of options soon. I really want to find one as a range extender for an ev pickup truck.
https://www.capstoneturbine.com/products/c30
The capstone 30kw lives inside a 30" wide cabinet with clearance. I've seen the business part (turbine, generator, heat exchanger less controls and cabinet ) its about the size of a modern V8 but cylindrical and lighter than the full dress engine . Ive been told the turbine/generator only (less heat exchanger) is about the size of 2 footballs end to end, the rest is heat exchanger. And still pushes 530°F exhaust (47kw waste heat) theas are proven in transportation their websites shows many case studies proving this. Granted 30 kw is probably a little overboard. Using a leaf pack as an example could run the Gen set for 1 hour and drive for 3 ( assuming they have cracked the code to allow charging discharge at the same time)
Dream Big Chisel Down To Reality
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
![](http://ecomodder.com/forum/fe-graphs/sig8842a.png)
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
