Old 07-13-2018, 02:44 AM   #10 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Apparently typical bsfc is on plane 5000rpm at throttle valve fully open (volumetric efficiency) with a mpg prop... big prop that wont let the motor rev up. So currently I run 100% throttle, 5000 rpm (max hp is 5500... max rpm is 6000 rpm). And.... I get a whopping 9 mpg lol. 15' flat bottom 25 mph. 90s yamaha 2s 30hp.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
The Following User Says Thank You to hayden55 For This Useful Post:
redpoint5 (07-13-2018)
