Old 07-14-2018, 03:19 PM   #2 (permalink)
redpoint5
90 day: 29.78 mpg (US)
No measured data to share, but my sense is you are correct in your assumptions.
Most vehicles have fairly high electrical draw just running the fans, perhaps around 200 W on high (measured the TSX at 220W). Even lower settings often have a high power consumption due to the resistors that many fans use to control speed. Factoring in the losses involved in generating that electricity, we might be looking at half a horsepower or more in required engine power.
A typical AC might take 3 HP when it runs, but since it runs intermittently (cycles on and off), the average power draw on the engine might be closer to 1.5 HP. The general rule is a 10% drop in MPG running the AC, though I suspect that also includes the power required to run the fans.
My best guess is that your fans drop MPG by about 4%, and if you were to run AC, it would drop it an additional 6%. If you have a gauge that measures fuel consumption at idle, you might be able to get a rough estimate of the extra amount of fuel needed to run the fans, as well as the extra amount to run the AC. You'd need to keep track of the % of time the AC is running vs % of time it is off to get an accurate average of the AC consumption. The other factor in AC power consumption is that it has to run a higher % of the time when cooling a heat-soaked car, and runs less frequently to maintain temperature in an already cooled cabin.
Cracking the windows is probably negligible depending on how open they are and the speed driven.
MetroMPG (07-21-2018)
