Originally Posted by Daschicken
I was actually reading up on this subject earlier, and chances are boat efficiency is very closely related to airplane efficiency. One big thing I found is that jet drives are not as efficient as props. Just like planes, you will gain efficiency from large diameter 2 blade props, more blades=more turbulence.
No idea on hull design and water interference yet, haven’t looked into that enough.
That is really disappointing. I believe the BF60 engine is closely based on the 1st gen insight engine, and comes with lean burn.
If you do a little research, you'll find out that 8mpg is really good for a boat. Although my boat is lighter than that Insight that you're somehow comparing it to, the drag and single speed make this an apples to freesbees comparison.
