Old 07-19-2018, 10:52 PM   #21 (permalink)
Dark Egg - '12 VW Touraeg
Originally Posted by hayden55 View Post
Can anybody explain how to use that calc for a 15' flat bottom? lol
Use the planing hull and you need the weight, it should be pretty close. A flat bottom with enough power is the most planing hull there is, the v-hulls plane but are designed to keep a cut in the water for stability on waves and turning. A semi-displacement hull is the most inefficient trying to do both a smooth ride and good speed, think James Bond yachts. Who cares how much gas costs because money is no object. There are some exceptions but speed is always a consideration. They will make claims like most efficient design over 15 knots. Displacement hull are traditional ships and sailboats. They are the most efficient hulls speed not a factor. Yet with enough length they can also be pretty fast. The French built a 434 ft long destroyer that ran 52 mph. I would love to have seen that flank speed, boilers at battleshort pressures, blow by.
The Following User Says Thank You to Hersbird For This Useful Post:
hayden55 (07-28-2018)
Old 07-23-2018, 12:57 AM   #22 (permalink)
NatGasser
CNG Civic - '11 Honda Civic GX (Compressed Natural Gas)
90 day: 41.42 mpg (US)
Originally Posted by Daschicken View Post
I was actually reading up on this subject earlier, and chances are boat efficiency is very closely related to airplane efficiency. One big thing I found is that jet drives are not as efficient as props. Just like planes, you will gain efficiency from large diameter 2 blade props, more blades=more turbulence.
No idea on hull design and water interference yet, haven’t looked into that enough.
That is really disappointing. I believe the BF60 engine is closely based on the 1st gen insight engine, and comes with lean burn.
If you do a little research, you'll find out that 8mpg is really good for a boat. Although my boat is lighter than that Insight that you're somehow comparing it to, the drag and single speed make this an apples to freesbees comparison.
Old 07-23-2018, 04:23 AM   #23 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Try using a kite to pull the boat.
Old 07-25-2018, 03:42 AM   #24 (permalink)
I would say this closer to the ecomodder solution:
That's quite common in Amazon.
Old 07-25-2018, 11:52 AM   #25 (permalink)
In Vietnam they stick the long tail down a pipe and use it to pump water in the rice paddies. In Thailand they race.
https://duckduckgo.com/?q=long+tail+...deos&ia=videos
Old 07-25-2018, 10:30 PM   #26 (permalink)
IIn Thailand they race.
What does surprise me about the usage of those long-tails in Thailand is they fit it to nearly every Diesel engine regardless of size.
Old 07-28-2018, 06:42 PM   #27 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
They use them here as well. Well, we call them mud motors. Basically makes it to where the boat can go anywhere hunting wise. The Game and Fish comission about bans them every single year so not something I wanna sink money into and then not be allowed on WMA land. Mostly, they are noisy and everyone hates them.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
Old 07-29-2018, 07:03 AM   #28 (permalink)
In Amazon they're used for general transportation. Even in big cities such as Manaus we see a lot of them in the "voadeiras". It's used there to prevent the propeller to get stuck on tree stubs below the water while crossing an igapó.
Well, soundproofing is not really a top-tier priority on those, but honestly it didn't bother me too much.
Old 07-29-2018, 01:08 PM   #29 (permalink)
I think the most interesting use is to make one an Archimedes screw (sorta), to pump water out of rice paddies.
Old 08-27-2018, 04:19 PM   #30 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
The boat I use most often gets about 150 MPGe on 8 210 amp hour 6 volt golf cart batteries 3 phase permanent magnet dc motor with 2 belts driving a prop shaft out the keel.
Cruise speed is 5 mph Flank speed is 6 mph, realistic range is 70 miles. It’s a 1982 Duffy electric packet.
Edit: here we are on our local river. https://youtu.be/rm2FhL8X4yU
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
