Old 07-23-2018, 11:19 AM   #69 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
Originally Posted by samwichse View Post
I would leave the Tom Mix bar in. That's absolutely part the side impact protection. If you take it out you'll see it's a pretty solid piece and bolted in 4(?) bolts at each end. I don't think you would really gain anything by taking it out unless you're planning to sleep in the car...
I won't cut the bar mounts out, will keep the bar until I'm finished with everything, and see then how I feel about it.
The bar has 3 10mm bolts at each end.
