Originally Posted by jamesqf
I figure the engineers who designed the Insight engine ought to know what it's designed for. All the rest of their engineering, including unconventional things like lean burn, seem to work just fine. And with 130K miles on the engine, at least 80K using the 0w-20, there's still not a drop of oil leaking anywhere.
They do. Check the shelves at your local WalMart :-)
I think the bad reputation comes from the F150 owners who have 0W20 recommended by Ford. 20 weight oil starts to sound like a bad idea when your engine has been outputting 150hp for the last 10 minutes pulling 12,000lbs up a 8% grade... Worst case scenario for sure but its hard to change your oil when you're half way up...
Most of the time engineers get trumped by the bean counters so I don't always think what is recommended is always best. It is a good place to start though for sure.
If I were you I'd keep using the 0W20 unless you get a 28ft trailer
