Thread: Class 8 Trucks
Old 08-30-2008, 01:23 PM   #31 (permalink)
jamesqf
Originally Posted by johnmyster View Post
The whole reason why your gas engine pulls fuel is in order to cool things off in the combustion chamber and prevent precombustion that a "hot mix" could be succeptible to. Um, precombustion isn't an issue in diesels. Forget about it.
Huh? Seems to me the reason the gas engine pulls in fuel is to burn it. Sure, there are some old designs - aircraft engines & two-cycles - that used fuel for cooling, but that's ancient.
Plus, why would you ever want to intake warmer air on a TURBOCHARGED AND INTERCOOLED engine?
Because it might give better fuel economy? As in maybe there's a good reason why those trucks have their air intakes located where they are?
Maybe your computer does something funny, but the basics of Carnot/Rankine cycle dictate that a cooler charge/sink temp is more efficient at harvesting the heat energy from the source. Always.
That's the same thinking that says an engine has to have an A/F ratio around 14:1, and can't possibly run at 21:1 or leaner?
I don't claim to be an automotive engineer. I just know what happens to the mpg display on a cool day, when the ScanGauge shows IAT around 60 degrees, and I hook up the duct that brings warm air off the cat to the intake. The mpg goes up significantly. If I said I knew for sure how or why this works, I'd be lying. I just know it does work.
