Old 07-31-2018, 01:32 PM   #69 (permalink)
engineered
Bimmer - '02 BMW 325ci
90 day: 23.79 mpg (US)
Since this has been revived, why not use a 12V block heater and/or 12V oil pan heater to heat up the fluids? They could be used manually or controlled automatically to come on with the car and turn off at a certain coolant temp (or from the tstat).
When coolant gets too hot it degrades and is no longer a useful coolant.
How would coolant water (and glycol) degrade? It doesn't break down like motor oil. I'm mean if you overheat it, it would eventually vaporize, but 98'C water is always going to be the same water.
