Old 08-01-2018, 07:48 PM   #29 (permalink)
Stacygifford
Eco Storm Chaser
Stacygifford's Avatar
Nemo - '87 Ford Mustang GT
90 day: 27.26 mpg (US)
K-sight - '02 Honda Insight
90 day: 39.24 mpg (US)
Originally Posted by California98Civic View Post
I like how you left the passenger side exppsed. .... Or maybe you covered it after this pic?
Lol about that.... I have the peice cut and ready to go under the car... I just got a little lazy. But yes the passenger side is much smoother. (Why I am saving it for last)
Thought I would add some higher quality pics with it actually clean under the hood.
I swapped out the super ugly stainless braided fuel line with some black nylon beaded fuel line. The only reason I used the ss lines is because they came with my cheap FPR. Unfortunately, they were super low quality. I highly recommend the nylon braided line even if only because it is easier to work with.
As you can see, the wrx injectors plug right in after a slight trim of the connector.
The next task is a subframe brace that will act as mount for a front bellypan.
Then, wire in the flex fuel sensor to the K-Pro and walborro 255 for some corn power. We will see if it is more cost effective with the correct tune.
