Old 08-03-2018, 12:23 AM   #11 (permalink)
redpoint5
90 day: 29.78 mpg (US)
I blew a corner once on my bike, but that was because I didn't heed the "bump" road sign. Usually bump means you can barely feel something in the road. This bump was more of a ramp, and the sign should have read jump instead of bump. The bike went airborne, and the suspension had not settled by the time I got to the corner, no time for braking. Tried to make the corner and lowsided. Slid to to about 15 feet from a cliff into the river below.
Accidentally covered the left side of my rear tire in oil once while riding home from getting oil for an oil change. I had dangled the bag off the rear of my bike, and the rear tire rubbed a very thin hole into the bottle, which then coated the left side of my tire. I found out after taking a left turn from a stop sign and did a 360.
Wanted to test the theory that new tires were slippery and should be ridden gently the first 100 miles. Made a left turn and got on the throttle a bit to see if it would get loose at all. It got loose alright, and I put the bike down.
Didn't put the kickstand down once. *facepalm*
Various lowsides on the track nearly every time I go. Didn't crash the time it rained, miracuously, even though the bike threatened to let loose with nearly every corner.
Originally Posted by Stubby79 View Post
Bald tires on the back, going around a tight corner on a canyon "highway", back end lost grip...my fault for trying to keep up with traffic, rather than driving at what I felt comfortable doing.
Really, normal traffic was taking corners beyond the capabilities of your vehicle? I would think something was very wrong with the handling characteristics of your vehicle if it couldn't handle what traffic was doing.
I've never seen anyone take corners as fast as I take 'em, and I don't push the cornering limits of my Prius. Maybe 80% of the limit, tops. Most people get uncomfortable using more than 30% of their cornering traction. They don't like lateral acceleration for some reason. I find that I don't like the absence of lateral acceleration.
