Old 08-03-2018, 12:19 PM   #37 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
The Meanwell power supply I have outputs up to 53 amps, and I currently have it set to ~14.0v. It's rated at typically 88% efficient, but I've bypassed its internal rectifier so it might be higher than that. The fan isn't supposed to come on until 35% load (+/- 15%) and for the most part it stays off, even when I'm blasting music. I often hear the fan pulsing when I run my turn signals (following the blink rate), roll down the windows, or have the HVAC system running plus headlights (low watt HIDs). So, if I were to guess, typically I'm drawing less than 20 amps during this drive, possibly less than 10 amps.
