Old 08-04-2018, 04:14 PM   #7 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by fusion210 View Post
I'll probably never find it again, but I read that they were the same tires used on the Cruze with less tread depth.
Let’s call that “misinformed “
The OEMs had a horizontally more narrow tread, but the depth was the same.
Tire rack usually lists 3 different Goodyear’s for the volt , the narrowist , lightest one is the true OEM but to be honest there isn’t much difference in RR between the 3 and the wider one is only about a lb more
Be up to the OP to decide if it’s worth it.
