Old 08-04-2018, 04:22 PM   #8 (permalink)
fusion210
Winsight - '06 Honda Insight
Gen-1 Insights
90 day: 72.19 mpg (US)
Originally Posted by rmay635703 View Post
Let’s call that “misinformed “
The OEMs had a horizontally more narrow tread, but the depth was the same.
Tire rack usually lists 3 different Goodyear’s for the volt , the narrowist , lightest one is the true OEM but to be honest there isn’t much difference in RR between the 3 and the wider one is only about a lb more
Be up to the OP to decide if it’s worth it.
When I looked into it the tire name and size was the same but the Volt tire did have less depth. You can call it misinformed, but that was the case.
