Old 08-06-2018, 09:56 AM   #1 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Member of IC consistently getting 130+ mpg
Here's a link:
Just got to know - Insight Central: Honda Insight Forum
Have had independent verification of these numbers. Seems like he has his IMA removed, and the bypass he's using has a bug which disables lean burn, leaving some additional economy on the table. His secret seems to be running astronomical tire pressure (120+) and keeping speeds low enough (~40mph) that rolling resistance is his primary drag. He (I think) doesn't use a deep cycle battery and just uses the Insight's original DC-DC charging, and aero mods are minimal.
Probably worth a read.
The Following 2 Users Say Thank You to Ecky For This Useful Post:
mpg_numbers_guy (08-07-2018), RedDevil (08-06-2018)
