Old 08-07-2018, 12:01 AM   #22 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Turtle
There's a way to calculate air density that I used to do when I flew because it is bad juju to take off from a too short runway. However in the enjoined 20 or so years I have forgotten it.
Local (salt flat) data is available every IIRC 15min from 2 weather stations1 at the start and 1 ~ 1/2 down the big track, so ambant air density is available.
YouTube can be good . Gale Banks did a good presentation on Manifold Air Density MAD and how that has affected how he chases power versus others .
I asked the channel if thay had access to the Hot Rod Calculator
There response
Banks Power
Ahh.. We don't have the calculator handy that you're referring to. We've requested a copy from HotRod.
Hopefully Banks has enough pull to get somebody to go digging in the archives and will share a sorce if/when successful.
MAD is one of my reasons why I am devloping a temperature controlled grill block referencing IC Nd engine coolent temperature. Cheep simple servo automated grill block active aero deployment. (Link). With additional blockages on other components that will open independently based on that components individual need. EG transmission cooler. this truck has a technical service bulletin advising not to drive the truck in overdrive below - 5F, this causes the viscosity to get to high in the air to liquid transmission cooler(aka it freezes) causing a restriction in the cooling circuit end result is' a burned-up overheated transmission, failure mode too cold. So I make shure that is blocked in winter( doesn't get hot enough to run without it covered in overdrive for two to three months where I live).
Don't wanna repost this whole thing, BUT, paste your data into excel and it will do graphs easy peasy
How do i get exel on to a Samsung Note 5? The xp computer dusent go online.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
aerohead (08-08-2018)
