Old 08-11-2018, 03:27 PM   #106 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by 19bonestock88 View Post
.... and I haven’t seen any HX wheels locally...
I also don’t know for certain that the Honda wheels would even go on... the bolt pattern is the same but I have no idea what the lug seats look like(conical or flat or ball socket shaped) or what the center bore diameter is...
The lugs are conical. The Honda rims for 5th/6th gen Civics (and maybe 4th and 7th, too): offset 35-45; bolt pattern 4X100; lug size 12mmX1.5; hub center bore 56.1mm minimum (larger center bore needs spacer rings)
